results failing
Altair Forum User
Hello ,
I am trying to visualize the static analysis of a solid. When the results appeared on hyperview I noticed that the maximum constraint of Von mises exceeds the elastic limit but only on one element. As shown in the figure. surely this element is a singular element .So I wanted to know how can i on hyperview or on hypermesh (optistruct) correct this element or to see just the admissible constraints .
thank you very much
Hi @jemaoui
You can get the element ID using query panel and correct the same in HyperMesh. It is not possible to correct the element in HyperView.
