on importing NX CAD file some bolts are identified whereas others remain general parts.
Any way to change this ?
Can I create bolts within SimSolid?
Ralph
SimSolid identifies special part geometry such as bolts and nuts which will be easier later in giving bolt/nut tightening load.
It does this automatically and cannot be changed. However, you can hide/suppress/delete the bolts/nuts.
And, it is not possible to create bolt within SimSolid.
