Hi all
what is the meaning of the number in tetcollpase blank which is by default set to 0.3 ?
The ideal shape for a tetrahedron element is an equilateral tetrahedron. Various quality parameters check how far a given element deviates from the ideal shape. And a similar quality parameter is tetcollapse.
Tetcollapse is defined as the distance of a node from the opposite face divided by the area of the face multiplied by 1.24.
Ideal Value of tetcollapse for a tetra element is 1.0 , and value greater that 0.1 is acceptable.
