I got a *.dyn file from sheet forming results, how could I to map the thickness property on another mesh file which is continuous in one component.
Show us your DYN file & your 'another mesh'
like such blanking shell, I need to map the forming thickness to the final product mesh model.
Do you mean:
- you have a mesh model named A
- you perform a stamping analysis, and got result as mesh B
- now you want to take thickness values in B and apply again to A, don't you?
Do you mean: - you have a mesh model named A - you perform a stamping analysis, and got result as mesh B - now you want to take thickness values in B and apply again to A, don't you?
Yes! Do you know how to map the thickness value?
Try invoke pulldown menu Mesh>Assign> Midmesh Thickness
at 'Input' => select 'From file'
at 'Solid geom/mesh:' => select 'FE' => browse to select stamping result *.dyn file (mesh /emoticons/default_cool.png' title='B)' />
at 'MidMesh:' => select your original file (mesh A)
click 'Calculate Thickness'
Hi, Try invoke pulldown menu Mesh>Assign> Midmesh Thickness at 'Input' => select 'From file' at 'Solid geom/mesh:' => select 'FE' => browse to select stamping result *.dyn file (mesh /emoticons/default_cool.png' title='B)' /> at 'MidMesh:' => select your original file (mesh A) click 'Calculate Thickness'
I have tried as you told, but it import these two mesh file together and the thickness contour shows no change for my target mesh,
actually I got the file I need but I just don't know how to realize.
So finally mesh A has been mapped thickness value from mesh B, is this right?
=> That is what you expected
What do you need more?
