Submitted by Andrwe Buckin on Wed, 04/27/2016 - 23:02
how to set a sampling for Ramp32 (C2000)?
thanks.
Andrew
Submitted by Sreeram_Mohan_Altair on Mon, 05/16/2016 - 16:26.
Hi Andrew,
You should be able to set the frequency in the compound block within Ramp32 as in the image attached.
In this case the $timestep is the simulation step time accessible in the System-> System Properties Menu and the frequency as you read in this case is 60 Hz.
Hope this helps
--sreeram
