how can i create a Surface mesh only with the data of the fe- mesh
In my case the fe mesh is the result of a Topology Optimation which i have reimported into hypermesh without smoothing.
I would like to 3D print the result of the unsmoothed Topology Optimation result and therefore i need a stl Surface mesh.
Is this possible? Thank you very much
Regards
Andreas
