When I was using HyperView to see my result.
Some times it will show
can't read 'Priv(where)': no such element in array
while executing
'if {$id(where) eq 'item' && $Priv(where) eq $id(where) && $Priv(item) eq $id(item)} {
ProcessSelection $W $x $y
(object '::post::pa::_hvpaobjpo_viewmodel' method '::hwtk::pa::Area::OnLMBRelease' body line 3)
invoked from within
'::post::pa::_hvpaobjpo_viewmodel OnLMBRelease .post_results.model.f2.hvpapo_viewmodel.ftree.tree 342 119'
(command bound to event)
What is the problem of my software.
Because I also can see my h3d in HyperView and it is normal to see result.
