I'm trying to execute a power balance over a full electric period of a 4 pole motor (180 mechanical degrees) but I get an error :
   evaluateInstances : Execution failed. Failed execution Failed to create a new instance of Power Balance.
   BP_ERES  => Wrong parameter BP_ERES  => failed... BP_FNUM  => Evaluation interrupted BAFOC2_1 => Evaluation failed BAFOC2   => Evaluation failed BAFOCC   => Evaluation aborted evaluateInstances => failed stdcom.error.SoftwareFortranException: evaluateInstances : Execution failed. Failed execution 	at cad.core.common.error.ErrorManager.createFortranException(ErrorManager.java:153) 	at cad.flux.kernel.dbmanager.FGCProjectDbWrapper.evaluateInstances(Native Method) 	at cad.flux.kernel.dbmanager.FGCProjectDbAdapter.evaluateInstances(FGCProjectDbAdapter.java:1004) 	at cad.flux.kernel.dbmanager.FGCProjectDbAdapter.evaluateProjectInstances(FGCProjectDbAdapter.java:961) 	at cad.core.kernel.dbmanager.DbManager.evaluateProjectInstances(DbManager.java:2081) 	at cad.core.kernel.components.TransactionCreateInstance.processDBEvaluation(TransactionCreateInstance.java:416) 	at cad.core.kernel.components.TransactionCreateInstance.commit(TransactionCreateInstance.java:330) 	at cad.core.kernel.components.TransactionManager.commit(TransactionManager.java:292) 	at cad.core.kernel.components.TransactionManager.processTransactionCreateInstance(TransactionManager.java:652) 	at cad.core.kernel.components.TransactionManager.newProjectInstance(TransactionManager.java:739) 	at cad.flux.kernel.FGSupervisor.newProjectInstance(FGSupervisor.java:3502) 	at sun.reflect.GeneratedMethodAccessor378.invoke(Unknown Source) 	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) 	at java.lang.reflect.Method.invoke(Method.java:498) 	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:186) 	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:204) 	at org.python.core.PyObject.__call__(PyObject.java:507) 	at org.python.core.PyObject.__call__(PyObject.java:511) 	at org.python.core.PyMethod.__call__(PyMethod.java:156) 	at pydb$py.newObject$203(pydb.py:1586) 	at pydb$py.call_function(pydb.py) 	at org.python.core.PyTableCode.call(PyTableCode.java:167) 	at org.python.core.PyBaseCode.call(PyBaseCode.java:170) 	at org.python.core.PyFunction.__call__(PyFunction.java:434) 	at org.python.core.PyMethod.__call__(PyMethod.java:156) 	at pydb$py.__call__$159(pydb.py:1261) 	at pydb$py.call_function(pydb.py) 	at org.python.core.PyTableCode.call(PyTableCode.java:167) 	at org.python.core.PyBaseCode.call(PyBaseCode.java:307) 	at org.python.core.PyBaseCode.call(PyBaseCode.java:198) 	at org.python.core.PyFunction.__call__(PyFunction.java:482) 	at org.python.core.PyMethod.instancemethod___call__(PyMethod.java:237) 	at org.python.core.PyMethod.__call__(PyMethod.java:228) 	at org.python.core.PyMethod.__call__(PyMethod.java:223) 	at org.python.core.PyObject.invoke(PyObject.java:3697) 	at org.python.core.PyInstance.instance___call__(PyInstance.java:377) 	at org.python.core.PyInstance.__call__(PyInstance.java:372) 	at org.python.core.PyObject.__call__(PyObject.java:405) 	at org.python.pycode._pyx113.f$0(<input>:1) 	at org.python.pycode._pyx113.call_function(<input>) 	at org.python.core.PyTableCode.call(PyTableCode.java:167) 	at org.python.core.PyCode.call(PyCode.java:18) 	at org.python.core.Py.runCode(Py.java:1398) 	at org.python.core.Py.exec(Py.java:1442) 	at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:276) 	at cad.core.kernel.components.PythonWrapper.runCode(PythonWrapper.java:628) 	at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:623) 	at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:598) 	at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:593) 	at cad.core.kernel.components.PythonWrapper.execute(PythonWrapper.java:638) 	at cad.core.kernel.components.PythonWrapper.executeNewCommand(PythonWrapper.java:756) 	at cad.core.kernel.KernelModule.executeNewCommand(KernelModule.java:104) 	at cad.core.kernel.actions.implementation.type.CreateInstanceAction.doAction(CreateInstanceAction.java:108) 	at cad.core.common.dynamic.actions.UIActionManager.postAction(UIActionManager.java:145) 	at cad.core.common.dynamic.actions.UIActionManager.postAction(UIActionManager.java:274) 	at cad.core.kernel.KernelCommon.postAction(KernelCommon.java:306) 	at cad.core.kernel.encoder.ActionServerRequestsInputPlug.postAction(ActionServerRequestsInputPlug.java:88) 	at cad.core.kernel.encoder.ActionServerRequestsInputPlug.postAction(ActionServerRequestsInputPlug.java:82) 	at stdcom.protocole.actionserverrequests.ActionServerRequestsRouter.postAction(ActionServerRequestsRouter.java:70) 	at stdcom.protocole.actionserverrequests.ActionServerRequestsOutputPlug.postAction(ActionServerRequestsOutputPlug.java:96) 	at cad.core.frontal.decoder.FrontalDecoder.postAction(FrontalDecoder.java:464) 	at cad.flux.frontal.actions.implementation.algo.postpro.ExecuteEntityWithResult.postAct(ExecuteEntityWithResult.java:63) 	at cad.core.frontal.actions.implementation.type.CreateInstanceAction.interpret(CreateInstanceAction.java:309) 	at cad.core.frontal.components.box.frontaldialog.FrontalDescriptorDialogBox.internalRun(FrontalDescriptorDialogBox.java:296) 	at cad.core.frontal.frontalthread.WorkerThread.executeImplementer(WorkerThread.java:226) 	at cad.core.frontal.frontalthread.WorkerThread.run(WorkerThread.java:274)
   	Also I'm having a hard time calculating the power balance manually. Because FLUX tells me that the power input is 6000W and the mechanical output is 4200W, however when I sum the joule losses+ the bertotti losses I get 4200+400=4600W. So where are the others 1400W (6000-4600) ?
   	I'm nearly sure I'm calculating it correctly. But I'm asking because I'm new to flux and I'm still understanding how it works. Is this difference normal or I am missing something?
   	I can give you my solved flu project, but I'd have to send it directly to you since the link expires after one download
 	Thanks, have a good day!
