where to locate the download for Monarch 16.1.1.0
Hi @Ian McGrath & @Paul Hanson ,
To locate the Product Downloads one can either locate them within Altair MarketPlace OR Altair Connect- Monarch. You will find these resources located when you select the waffle icon in the Upper Left Side next to Altair Community
If you select MarketPlace you will then want to Filter for the Product Suite Data Analyst and you will then see MONARCH listed amount the products.
From here will then Select on the Product Name and then will be presented with the next screen to Select the Version, Language, & OS and Download Option arrow will appear.
NOTE: You must be Signed Into AltairOne/Altair MarketPlace in order to see the Download, as well as, be on Current Maintenance & Support.
======= The other option is to Download from Altair Connect ==============
After Selecting Altair Connect you will then see Downloads Option Screen sharing the list of the various Software Suites and will want to select Data Analytics Products - SEE PRODUCTS
Upon Selecting, you will then See MONARCH along with the other Products. You will SELECT the Product Icon.
Upon Selecting PRODUCT, you are then presented with the Screen to Select the version, the OS, and application package with the option to DOWNLOAD.
NOTE: You must be Signed Into AltairOne/Altair Connect in order to see the Download, as well as, be on Current Maintenance & Support.
Should you run into any issues know that you may always contact our Technical Support Team at DASupport@altair.com OR you may create a Support Ticket right from the Community Home Page.
-Rebecca Cronin
kw-csm@altair.com
