spliting faces to apply load
Altair Forum User
Altair Forum User
hi,
to do the static analysis i usually use this procedure
1]do the part in solidworks, split the required faces to apply load.
2]then import it to hypermesh, mesh it. then export it in abaqus format to ansys.
3]then do the analysis in ansys.
the problem is,
when i import it into FE modeller in ansys. thee ansys will not show the split geometry i had created in solidworks. because of which i couldn't apply the required load on the specific part in the geometry.
kindly someone give suggestion so that i'll be able to solve this problem.
  • Altair Forum User
    Altair Forum User
    edited June 2014
    Split your faces within Hypermesh. Make your mesh and prepare some sets of nodes/faces/elements for your loading.
    Finally define your loading overs sets above.
    I have no ANSYS here to test. But this method works well with SAMCEF/Nastran/LS-DYNA/Optistruct,...
