im doing a study with different optimizations. In this case i compare the results without remeshing. For analysis i need to delete the elements which are not connected with the others.
In this case i have a lot of this elements. Is there a possibility for automatisation? A function in hypermesh to delete the floating elements...
Thank you very much
Andreas
