Hello everyone,
How can I open Matlab Simulink via Flux supervisor?
From Flux supervisor, you select option. After you go in access path, you select coupled software.
Best regards.
Hi Abdessamed,
I selected OPTIONS from Flux Supervisor (on the bottom left of the environment). A window opens. There is a menu on the left. Below ACCESS PATH there is not the option COUPLED SOFTWARE you mentioned.
How can I fix it?
Wich version of Flux you use?
