Is ist possible to multiplie all forces in one load collector times '-1'?
Background: I tranfert the forces from a model via field function to a new one but need the reaction forces
Hello Oli,
Not official way, but it works with attached video.
Thanks,
Imoto
Thank you much.
I figured that also out by coincidence but thought it is a bug. There is no offical way?
Hi
Did you try making a load collector with card image 'LOAD'. It provides a factor to multiply with your forces. Set it as -1
Thank you. It works with card image LOADADD and scaling factor -1
