Submitted by ATHIESH on Fri, 03/28/2014 - 09:39
I got an answer for creating a pulse with variable frequency from VisSim guys.I am getting the corresponding output in VisSim. But, when i am using target interface block to check the output in CRO. I am unable to check the same output in CRO [pulse with variable frequency, while changing the frequency in VisSim debug diagram ]. Which port (either GPIO or DAC) is used in debug diagram?
Find the attached files.Please let me know the faults.
Thanking you
Athieshkumar T NIT warangal
