I am trying to run a topology optimization in Inspire for my thesis which is one of my school's student formula teams race car uprights (knuckle) as shown in the picture. The optimization runs when the minimum thickness it kept at 0.25 in and maximum is kept at 0.75 in. As soon as the minimum is made anything less than 0.25 in, the optimization fails with the error attached in the images(insufficient disc space) although the minimum suggested thickness is 0.14572 in and maximum is 0.29144 in.
The issue is surprising cause the run history path is set to a drive that has 1.79 TB of free space.
Any help or fix on this issue is appreciated. I can send in the file for review if needed.
Thanking You,
Amogh Taraikar
