Hi;
Please how can i see in hyperview the mass of my design space of each iteration ?
Thank you
Mass after each iteration will be present in the .out file. Please check .out file.
the probleme that the .out fichier show me the mass total of model not the mass of my design space in each iteration..
You need to call SHRES card in the OUTPUT control card. This will write SH file (Which contains shape change of model after each iteration). Run OSSMOOTH operation loading SH file, it will give you optimized shape after each iteration. Then, you can calculate mass using Mass calc option.
SH file written after each iteration.
Please try above method.
Thank you very much sir
i will try it now
Is your issue resolved?
Yes Sir Thank you
