How do I deactiviate the transparency in 'Geom/edge edit' and '2D/automesh'?
Maybe you're working with solid geometry
press F2 > select entity type 'solids' > pick geometry > delete
or enter menu View>Command Window, type in the command window:
*settopologysoliddisplay 3 0
