Submitted by vinayak on Sat, 04/03/2010 - 21:35
Can someone post the description of the sample examples available with ViSim. I am looking for more details on HeatExchangerLMTD.vsm
Submitted by Richd on Tue, 04/06/2010 - 04:13.
method for calculating output temperature of two fluids of given initial temperature and mass flow. You can select parallel or cross flow configuration. It also accounts for heat flow from metal piping and enclosure at initial temperature. You can learn more about LMTD here.An updated version of the heatExchanger.vsm with improved in-diagram documentation is located below (if you are signed in)
