hii all,
I have created a meshed model of a cube in hypermesh.I edited the input deck (after exporting the model) and defined a substructure in it.I want to call this substructure part in hypermesh and attach it with the global model while maintaining the node connectivity.Any help is appreciated.
Thanks
Hi Madhav,
Not sure if I understood your question correctly, but what you can do is you can import the file in HyperMesh and equivalence.
