TetraMesh volume with floating 2D features
Hello all,
Thanks to the great advice i received here, I have made progress with my project.
I am trying to mesh a rather complex reservoir geometry. it consists of a box with 2D elements floating in it representing fractures. I have generated the 2D mesh of the fractures and the bounding surfaces using HM and the quality is good. (picture attached)
I would like to generate a tetramesh of the geometry with one major contraint, the 2D elements must have shared nodes with the generated tetra elements.
I am not sure which one of the tetramesh options I need to use to ensure this.
Volume Mesh does not seem to work, any advice would be greatly appreciated!
Cheers,
Ariel
I thought there would be different approach for the complex geometry because I keep getting errors with Tetra Mesh.
Should I select Anchor nodes?
Have a look at this thread
The same question, the same problem, why changed topic?
