Hello. I have two components with a different set of meshes for each. The first component is just a meshed solid cuboid. The second component is a series of solid meshes which are located inside the geometry of the first component.
I would like to keep the two components separate but for the two components/sets of solids to act as a single solid. How would I do this?
Hi Hypernoob,
You can either connect them with RBEs or equivalence nodes of two meshes (provided they are with in a tolerance range).
