I'm finding some problems using the command 'Trim with line': in the tutorial after using that, the solid part trimmed is separated from the original one, so it can be Organized in a new component.
In my case, I trim successfully the part but is still united to the bigger one ( if I switch off the component it disappear completely).
Someone can said me what I'm doing wrong?
Thank you.
Alberto
