I've a problem with my 3PB model of a sandwich structure (honeycomb core). Contact between sandwich structure and supports isn't realistic. I set contact in 'SLIDE' but the result is wrong. So I obtained a displacement of 177 mm with a force of about 15000N, not real. I can't also view the results of CFAILURE, but I've set it in output requests.
Can you take a look to my model?
Thanks in advance. Hearing from you.
Regards.
