Adjusting mesh size in selected areas of a 3D object
I am trying to adjust the mesh size in a cylindrical object. Is it possible to vary the mesh size in a 3D object. Using tetramesh, when I select the mesh size to 4, the whole solid is selected but I only want one part of the object to have a mesh size of 4, and the rest to remain at 5 or 6.
Please tell me how I can do this.
Thank you
Kind Regards
firstly split the geometry in the region where you want to mesh with element size 4. Go to 2D meshing panel and mesh this surface with element size 4. Choose the remaining surface and mesh it with different size as required. Now go to 3D mesh panel ->Tetramesh -> Volumetetra -> choose the solid to be meshing and tick the match existing mesh option.
Hope this helps you.
Punith
Hi Punith,
I will try this right now. The meshing time takes forever.
Punith
Hi Punith,
Could you please explain where I have to go to split the geometry. Is it in the 'solid edit' panel?
Thank you
I recommend you to go through https://altairuniversity.com/learning-library/?type=learninglibraryitem&search=tetra&filter_resource_type=&filter_discipline=&filter_language=&filter_source= which has interactive videos and tutorials on tetra meshing, in which -'Meshing of a Steering Wheel' tutorial is there showing solid editing options.
Hello George,
Thank you but I am not exactly allowed to watch videos during work.However I managed to figure it out. Thanks again.
Kind Regards,
The above mentioned tutorial is a pdf file and I'm attaching the same for your future references.
Hi george,
Thank you, this is very helpful.
Kind regards
Punith
