Submitted by Joe on Fri, 06/19/2015 - 19:45
I am using a 'slider' block to control the value of a 'gain' block whose value is defined by a 'variable' set by the 'slider'. When I run the simulation, the 'gain' does not change according to the 'slider' value, what is going on?
