Hi ,
In my Rope Model I wish Material law 36 for a beam element. Hence forth I have used matlaw 36 with int beam.
I am still getting a error.
ERROR TRAPPED : REPORT TO LISTING FILE ERROR ID : 760
yours sincerely,
kartik
Hi Kartik,
This error is due to the /PROP/TYPE18 defined in the model. FOr the ****=1. input the Local Y coordinate of the integration point, Local Z coordinate of the integration point and Area.
Also, for the /TH/BEAM, input the variable as DEF, so that all the default outputs will be available in the time history.
Please correct these and try running.
