Help file says periodicity in a model can only be deleted and set again but cannot be edited. However I get this error when trying to delete a periodicity.
POINT already existing.
£1 : delete abort.
To delete the peridoicity, you need to delete in the first the mesh. Keep me informed if this solved the problem.
Best regards.
