Submitted by ramkumar on Mon, 09/10/2012 - 21:37
I see that SVM in vissim is making use of pulse centered SVM approach. Hence, it is getting different output(-1 to 1 range) than the normal non pulse centered SVM aprpoach. Note that there is also a small relationship where Vissim_PC_SVM_output. = 1- 2* NPC_SVM_output.http://www.vissim.com/forums/incorrect_output_or_least_confusing_documen...
But I did not understand the logic behind the scaling block between SVM and ePWM block. To reproduce the above problem, use the „acim_vf_openloop50Hz_sim.vsm“ and „acim_vf_openloop50Hz_sim.vsm“.
http://www.vissim.com/forums/how_use_sv_pwm_vissimecd#comment-101 Here if f= 0.7, then v= 0.789, SVMop = (-0.789 to +.789), ScalingOp = (+0.106 to 0.895) and not (0 to +.789) Again if f= 0.2, then v= 0.5789, SVMop = (-0.58 to +.58), ScalingOp = (+0.21 to 0.79) and not (0 to +.58)
I could not get clarifications for the below questions:
- Is this scaling correct? Here is my concern: I see a relationship viz. Scaled output =0.5 +0.5Vissim_PC_SVM_output. (i.e. pulse centered output using general TI document). But also Vissim_PC_SVM_output. = 1- 2 NPC_SVM_output (i.e. Non pulse centered output using general TI document). That means Scaled output =1 - Vissim_PC_SVM_output.
a. Clearly this scaled output is giving toggle value of the non pulse centered output. So, why are we doing this?
b. Also, I see that in the example of „acim_vf_openloop50Hz_sim.vsm“, the output from scaling block are fed directly to the ePWM blocks. But, the example uses the following configuration for the action qualifier,
ePWMA: CA Up: 0 ; CA Down: 1
ePWMB: CA Up: 1 ; CA Down: 0
However, as per TI documentation http://www.ti.com/lit/ug/sprug04a/sprug04a.pdf (pg 80), we should use the below config:
So, are we using output of duty cycles as cmpa signals (when in fact cmpa signal and duty cycles are complementary)?
c. Also, we are again converting a pulse centered switching sequence into a non pulse centered switching sequence (although with a toggle status). Are we then not losing the advantage of the PC output approach?
- Is there any way that I can have a non-pulse centered output instead of getting PC output directly from SVM? How do we do that? Then we do not need any scaling for ePWM.
Thanks!
