Submitted by lxman on Wed, 03/28/2012 - 16:56
I have taken the ADCtestF28069 example and modified it for learning purposes. Instead of using the direct monitoring of an analog channel, I have changed the program to use the Monitor Buffer facility. This is working well, except for the following:
I have sized my buffer to 2500 bytes (or is that words?). Over the course of ten seconds, the buffer updates twice on the plot - an average of five seconds to fill the buffer. This makes me think that the ADC is sampling at about 500 Hz. I need about 2 MHz sample rate on one channel.
Could you please check the attached files and tell me what I have incorrectly configured?
Thank you in advance.
