Spectrum digital XDS510LC JTAG Emulator reset
Submitted by Mala Gowda on Fri, 10/05/2012 - 09:56
Hello:
Emulator gets reset. when i am driving the motor. i am using TMS320F28062 microcontroller. i notice 3.3V supply is still alive. how would emulator gets reset in between hardware in loop simulation. i notice this after 3 mins. what could be the reason.
Regards, MALA
Submitted by Anders89 on Mon, 10/08/2012 - 04:50.
The usual reason for JTAG comms loss with high power switching gear is due to lack of isolation in the JTAG emulator. When debugging high power switching you should use an isolated JTAG emulator. A device like this should help
0 -
Submitted by Mala Gowda on Fri, 10/19/2012 - 09:57.
Is there no other way out to solve this problem.. i notice JTAG Emulator is placed near to MOSFETs. Is XDS510LC emulator getting reset because of 10K-40KHz switching of Mosfets?
0 -
Submitted by Anders89 on Sat, 10/20/2012 - 05:40.
You should try to keep the JTAG cable as far away as possible from the power switching elements. We have seen the problem solved simply by moving the JTAG pod away from the MOSFETS. You could also try adding shielding foil to the JTAG pod cabling.
0 -
Submitted by koenig on Thu, 01/08/2015 - 22:19.
TI driver error 1137. PTI_ERR_RESET_TARGET
--> What does it stand for and is there a general description for errors?
0 -
Submitted by pete on Thu, 01/08/2015 - 23:25.
This error comes from the TI JTAG driver. It means that the emulator could not reset the target.
