What do i need to set the requests if i want to calculate the consult of the amplitude and phase in different locations.
I use a plane wave as a source.
Hello sid,
I don't understand your question. If you want to look and the amplitude and phase at different near field locations, you need to add a near field request (or multiple of them). An example would be something like example 'C-2 RCS and near field of a dielectric sphere' in the example guide. I would recommend that you work through the Getting started guide first to get accustomed with the FEKO interface.
Does this help? If not, try to rephrase the question or provide more details regarding what you are trying to do.
