RBE 3 same dependent but different independent (for different load cases)
Updated by Altair Forum User
I have different load cases applied at the same location, my problem is that i have to put different independent nodes from a same dependent note,
1 Case for a Z load
1 Case for a Y load
1 case for a X load
Foe each case, the load will be applied on the same dependent node, but due to geometrie, the independent nodes will be different, i try to duplicate the node, but i can choose the node to take and apply the 2nd or 3rd load cases.
1 - 3 of
31
Hi agaon,
I have a question,
I have done both RBE definition with the dirrerent forces, but on the same dependent node,
When i just xwant to use the X load for exemple, are the independent nodes for Z load inactive?
Hi Ducret,
Please check out below video. Is this what you are trying to do?
Thank you
