I edited the surface to make it more uniform. See attached (captured 2 is the edited, captured 3 is the original). Is it possible to create a hex mesh from this edited surface?
Also, please check out the layered mesh that was made. Is there any way to make this 100 percent (inside and outside) hex meshed?
Thank you,
