Hello all,
I was working on a model using hypermesh. I accidentally deleted the geometry, but the meshing is completed.
My question is, is there a way to restore my geometry?
Hi @jzy200
Unless you have a backup of the model, you cant restore the geometry.
Once you save a file, all previous data history will be deleted
If you are in the same session, then you can use undo option.
you can try the following:
-recreate geometry from FE: Geom>surfaces>from FE and if there are solids combine the surfaces with Geom>solids>Bounding surfaces
-if you have CAD geometry file: import geometry and then associate the nodes to geometry by Geometry>Edit>Nodes>Associate
