Submitted by Joe on Fri, 02/13/2015 - 05:30
How is the VisSim plot block used to display a signal versus frequency, like a power spectral density?
Submitted by Ric on Fri, 02/13/2015 - 20:46.
The “External Trigger” selection “plot” block can be used to display vector data. When using this option, the “plot” block plots vector data values (y-axis) versus the data index (sample number on the x-axis). The data index can be scaled to a range defined by the “X Upper Bound” and “X Lower Bound” values in the “Plot Properties” “Axis” tab. See attached example block diagram.
Submitted by pete on Fri, 02/13/2015 - 22:03.
Cool!
