Does have any tool to transform RBE3 into MPC ?
Or if doesn't have, how to create a communication between two cavities by hole, I read the manual, but is was not so explained.
Thks,
Moraes Marcelo.
Hi @Marcelo Soares Moraes
You can use this script to convert RBE3 to MPC which is available from https://connect.altair.com/CP/kb-view.html?kb=41108
You need to login to get access to the script.
