Altair RISE
Nominate Yourself Now!
Maillage incoherence with material properties
User: "Altair Forum User"
Updated by Altair Forum User
Hi !
I have a problem meshing my geometry with quads, so I did it with triangles. I am doing a simualtion of composie forming and to modelate the resine behaviour i use MAT/LAW59... when i execute the calcul, it stops without erros but with this warning:
** WARNING IN INTERFACE
DESCRIPTION :
   -- INTERFACE ID : 13
   -- INTERFACE TITLE : Punch-Blank Contact
   DEPTH 0.5000000000000 IS BIGGER THAN THE MINIMUM SIZE OF THE SLAVE SEGMENTS 0.1091826659199
   IN INTERFACE ID=13; PERFOMANCES MAY BE AFFECTED
  POSSIBLE IMPACT NUMBER:           0  (<=           1 *NSN)
I looked to the information sheet of the MAT/LAW59 and read that law is only conpatible with 8-noded hexadedron elements (/BRICK)... so I supposed that the problem may come the mon maillage with triangles. Can you tell me if I am right in my supposiions? anf which material law could I utilise to modelise 6-noded triedral elements?
Thank you very much!
1 - 1 of 11
    OP
    If I try to do the maillage wih quads this is the error I get :
        while executing
    '*elemoffset 1 1 0 0 0 8 0 [lindex $positionZPlyList $k 0] 0 $orientShellOffset 0'
        (procedure 'MultilayersResinModelling' line 93)
        invoked from within
    'MultilayersResinModelling '
        (procedure 'CreateInputData' line 47)
        invoked from within
    'CreateInputData'
        invoked from within
    '$itk_component(hull)-itk_hull invoke'
        while executing
        invoked from within
        invoked from within
    'CreateInputData'
        invoked from within
        while executing
    '.composite.labelFrameApproach.createInputButtonBox.bcreate_input invoke '
        invoked from within
    '.composite.labelFrameApproach.createInputButtonBox.bcreate_input-itk_hull instate {pressed !disabled} { .composite.labelFrameApproach.createInputButto...'
        ('uplevel' body line 1)
        invoked from within
    'uplevel $itk_component(hull)-itk_hull instate $args'
        (object '::.composite.labelFrameApproach.createInputButtonBox.bcreate_input' method '::hwtk::interface::HWIWidget::instate' body line 2)
        invoked from within
    '.composite.labelFrameApproach.createInputButtonBox.bcreate_input instate {pressed !disabled} { .composite.labelFrameApproach.createInputButtonBox.bcre...'
        (command bound to event)
