Mesh Problems
Hi Sirine,
The surface may be sharing an edge with the curved surface. Can you select the curved surface separately and mesh.
0 -
Hi Sirine,
I think the edge is not properly captured.
Can you please share the model file so that we will get an idea on the model.
0 -
unfortunately I can't do that because of secrecy issues.
But the curved surface is a Skin vehicle which I created with ruled surface (node path from girder elems which are curved) then I did an Offset and shrink of the surface. I hope the way I created it could help.
Thank you
0 -
Hi Sirine,
This could be a graphics issue. Only if we can see the full model we can comment more.
If you still feel it's not a graphical issue and the edge is not captured, you can project the nodes to the line.
