Submitted by Joe on Sat, 09/29/2012 - 10:24
Thank you very much for the advice. I was able to start with your example and get everything working.
Just a few more questions:
Is there any way to left justify the block title for a userFunction? I list a bunch of parameters in the title of my block and it is very hard to read. If I left justify it, it would be easier.
If this is not possible, is there a way to make it so that right clicking brings up the file chooser dialog (which I've already programmed) but then double left-clicking brings up a different dialog that would display the static parameter values?
How do I add custom block menus to the VisSim drop down bar? I'd love to have custom submenus where I can select my custom .dll blocks. It would be great if they were accessible from the main Blocks drop down window.
Every time I insert a userFunction block, I have to add in all of my connectors before linking it to the .dll because the connectors aren't automatically added when I load the .dll to accommodate the correct number of inputs and outputs. Is there a way to have this done automatically when the .dll is linked to the userFunction block?
