Error with TargetInterface - "Your block differs from dsp arg count"
Submitted by murthyakella on Mon, 04/16/2012 - 21:07
I was trying to implement an example code in realtime using target iterface. However, I am getting an error: 2Your block differs from dsp arg count.' Also, I see that the target frequency is shown as 0 in the tragetinterface properties windows. I am also attaching the files for your reference. Does anyone know the reason and solution for this problem?
Regards, Murthy
Submitted by Anders89 on Tue, 04/17/2012 - 04:26.
The problem is that you configured your source diagram, 'test_acim_tutorial_4_sim32.vsm', for the F28069. You must select MCU Config... and choose F28335 if that is your target. You must configure both the source diagram and debug diagram for your intended target.
0 -
Submitted by murthyakella on Tue, 04/17/2012 - 16:19.
Thanks a lot for the quick reply. It solved the problem. /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
Regards, Murthy
