Hi, I have saved a template file .tpl to plot some data of a node number. Hoe can I pass a new set node numbers of varibales and reuse the script.
Thanks in advance!
Hi
I do not clearly understand your issue. it seems you want to refer to some certain nodes in template. you can move your nodes to a temporary include and refer to them by dataname 'includeid',
or better way, create a set of those nodes, and in template, scan sets() in database, using pointer to ids dataname and access nodes by pointer.node.id/x/y/z ...
