In Hyper- Spot command
If I change mesh pitch smaller, the area that RBE3 connect is smaller. Therefore, the stiffness of welding get weak.
To prevent this problem, I want to set RBE3-dia by a value that not depend mesh pitch.
For ref see the attach image.
How to set in Hyper?
PS: In ANSA soft that command is 'RBE3-dia'
