Kindly help to make the macro which is used to load the many input and output files in a folderin hyperview and to atomatically apply the desired result.
can u pls elaborate..
For ex: The nastran deck is same but the load is applied at different locations. So i need a tcl macro which will call the input (.dat or .inp )and output (.op2 or .odb) in the order wise in Hyperview and apply the desired outputs. Instead of calling all the files separately , it will be easy if done through macro.
Why don't use multiple load steps?
