Hello all,
In the help manual, there is an example about command hm_allentitiesinfo. What's the meaning of outputs of command hm_allentitiesinfo? for example, {base 1 1 1 3} , what's the meaning of each parameter?
Roy
I think several lines above that example will explain output namely, please check.
Hi @tinh,
I have not found it in the help manual about this command hm_allentitiesinfo. Could you show me where to find the explanation?
It is in reference help. I don't have hm, cannot show it. Please find it your self
@Roy Duan, it is written here. So you can find more info in hm_entityinfo.
