Transferring forces between surface meshes
Dear community,
another question from an Optistruct beginner!
Let's say I have 3 square surface directly above each other with a distance of about 10mm. Each surface is inidivudually 2D meshed.
Now I apply two forces, one to the top surface, one to the bottom surface, both parallel but opposing each other.
It basically looks like this:
Imagine as if it was a composite part and each surface respresents one ply. I would like to transfer these loads through these plies. (I am aware that I am missing an SPC and that there are easier ways of representing composite parts)
Not to the question: How can I 'connect' the elements one by one to the elements of the next upper surface so that loads will be transferred?
I tried using RBE2 und using two faces, but two problems arise: 1. I cannot analyse the part anymore (Error codes that Google wont give me an answer for) 2. The resulting connection looks like a spider-web, so the loads would be transferred to the wrong elements of the adjacent surface.
Any help would be greatly appreciated.
Lenny
Thanks, this seems to work! I have been playing with the FREEZE contacts all morning to understand their behaviour.
Does the FREEZE contact only transfer loads from master to slave and not back? I don't quite yet understand how contacts work.0 -
