Minimum Meshing Wire Segment Radius
User: "Altair Forum User"
Updated by Altair Forum User
I am trying to simulate a probe fed proximity coupled patch antenna (center frequency= 4.5 GHz). When I am taking the meshing wire segment radius to be lambda/10 or lambda/20, it is showing an error message which says that the wire segment radius is too large. What should be the correct wire segment radius in this case?
Furthermore, I am observing that as I am reducing the radius to around 0.5 mm, it is showing a drastic improvement in the reflection coefficient and VSWR plots. How far can I go on reducing the wire segment radius? What is the minimum value?
1 - 1 of 11
    User: "Mel"
    Updated by Mel
    Hi Bidisha
    The wire radius should be set to the physical wire radius. E.g. for SMA connectors that would 0.65 mm. The radius affects the inductance of the pin and, as you observed, will affect the VSWR, etc.
    FEKO does not have a minimum radius as such, but given the above, it would not make sense to do this.
    Sidenote: FEKO uses the thin wire approximation, meaning it assumes the current flow is only axial on the wire. Sometimes if the wire radius is very thick, current flow could be radial as well, then this approximation is no longer accurate. Then it would be better to model the pin with a cylinder that will be meshed into triangles.
