hello i am new user of hyperwork, i wonder how to apply point load at a specific location without node?
thank you
hello i am new user of hyperwork, i wonder how to apply point load at a specific location without node? thank you
Maybe a pressure?
hello,
after I created the temp nodes and apply the forces and run the optiStruct, I received this error
ERROR 2148
Invalid design problem
All the sensitivities of response 1 objective are zero
How can I resolve this problem?
Are you doing Optimization in OptiStruct?
If so please check your responses and objectives as there is some problem in them.
Thankyou
hello, after I created the temp nodes and apply the forces and run the optiStruct, I received this error ERROR 2148 Invalid design problem All the sensitivities of response 1 objective are zero How can I resolve this problem? thank you
temp node must connect to structure (element), use RBE2 or RBE3, ... to connect it
