Dear Sir,
how to view and change 1D element normals in Hypermesh?
Thanks in advance
Gopi
To reverse normal of 1D
Just enter panel 1D>spotweld>switch node
Pick elems and 'switch'
To reverse normal of 1D Just enter panel 1D>spotweld>switch node Pick elems and 'switch'
ok, Thank you sir.
i would like to ask one more question i.e
Q) how to export material data (including E, NU & RHO values) to CSV file in hypermesh?
Hi Gopi T
There is no direct method available for this. You can use a TCL script.
Try this script attached here.
The output file will be saved in your document folder.
Thanks
Hi Gopi T There is no direct method available for this. You can use a TCL script. Try this script attached here. The output file will be saved in your document folder. Thanks
ok,
thank you sir
Hi Sir,
How to view 1D Normal in HyperMesh..?
Hi Makesh,
I can suggest orientation review tool. It might work
You can also examine this topic.
In aerospace module there is a matrix browser . You can query many thing like material, property etc..
Then you can easily export excel file.
