I am doing constant radius analysis but getting this error. How to resolve this ? I am using Hyperworks 17.0
Hello Adit - Are you able to run any other models ? Is this the only model that you have trouble ?
Are you able to run a simple model, say from MotionView tutorial MV-100 ?
regards
praful
Yes, I am able to run other models . I have trouble in this only.
How may cores are you tryng to run for the simulation ?? I think it may exceed the units you are allowed to use for your license.
If not. please try go to 'my document' folder, delete all file with 'hm' it it name and reopen the file
