hi,
how to review the local system coordinates in hypermesh? I want review the a,b&c node locations. that means system coordinates w.r.t that particular system.
thank you,
Hi Gopi,
Right click the System in System Collector and select XRef Entities, It will open References panel, you can review the system in that panel.
Hi Gopi, Right click the System in System Collector and select XRef Entities, It will open References panel, you can review the system in that panel.
Thank you
